Hi Everyone, i am trying to reproduce a shot i saw in a reel, several gummi bears bouncing in a floor.
In the scene i did, I made a DOP network for a single object (a cylinder with squishy object attributes to be replaced with a Gummi Bear model later and a ground), after that i put a copy node (putting a stamp parameter) with a grid as template, and a timeshift node (pointing the stamp parameter to avoid all copies fall at the same time).
But I don't know how to randomize each copied object's rotation.
I uploaded the hip file if you wanna check it and suggest me some solution. Any advice will be appreciated.
Thanx in advance!
Randomizing copies on a DOP Network
2317 2 0- Drex
- 9 posts
- circusmonkey
- 2624 posts
- Drex
- 9 posts
