Is there a function called PostSaveScripts
   2139   4   1
Hi, guys.
Is there any function called PreSaveScripts or PostSaveScripts?
Or can I use my function to override the default one?
So I can do some checking before saving the hip file.
If something wrong, the user can not save the hip file.
Is it possible to do that?
MainMenuCommon is the file you're looking for, remove the standard save entries and replace them with your own that do the pre/post save functions.
it might also be useful than to overwrite the shortcuts for saving to use your function
Infernal
Thank you.
I found that file and I found the save script:
<actionItem id=“h.save”>
<label>Save</label>
</actionItem>
It seems like the command is h.save.
My question is that where is the definition of h.save?
If I make my function, how does houdini call my function?
have a look here
http://www.sidefx.com/docs/houdini12.0/basics/config_menus [sidefx.com]
Thank you.
This is pretty cool!!
I'm researching on it.
Infernalspawn
have a look here
