12.1 HD Apprentice to 12.5 update not HD?
6436 8 2- chikega
- 26 posts
- robonilla
- 84 posts
- will c
- 57 posts
I am experiencing the same problem. I purchased the HD edition yesterday which appears to have installed a license for 12.0 but not 12.5. I did the install licenses thing through the license administrator and that didn't change the situation.
The License Administrator shows
Houdini-Master-NonCommercial 12.5
Render-NonCommercial 12.5
Render-NonCommercial 12.0
Houdini-Apprentice-HD 12.0
I assume that last one should read 12.5. Any other ideas? Thanks!
Will
Will
- 990adjustments
- 3 posts
Hey!
New to the forum here. Just wanted to chime in.
I have the same issue. I have a H12 Apprentice HD license but I show no entitlements for a H12.5 license of Apprentice HD and my H12 license has not yet expired. I assume I am eligible for this upgrade as stated in the purchasing terms.
I went through the license manager and it shows the same:
Houdini-Master-NonCommercial 12.0
Houdini just runs as the free edition. I only have three months left on my H12 HD license so I was just going to purchase an upgrade to H12.5 HD but I'm hesitant to do so if this is an issue.
@990adjustments
- JuanDos
- 35 posts
- Jenny
- 121 posts
Hi All,
If you are not seeing the H12.5 licenses that you think you should have, please contact Support@SideFx.com. Please let us know the name, or e-mail address, under which your H12.5 license was purchased. And also send in a License Diagnostic for your computer
To obtain diagnostic information, please open the license administrator, (from the Applications menu, under the Houdini folder), and go to View -> Diagnostic Information.
Support will work with you to get this problem solved!
Side Effects Technical Support
- 990adjustments
- 3 posts
- will c
- 57 posts
- storyteller
- 11 posts
For me this does not work. I've bought my license on 11.3 which is of course a 12.0 license. I have tried to install the license again, by returning and checking out using the licence administrator but I always get a 12.1 HD Version. So the question is, is it possible to update a 12.1 HD version to 12.5 HD ?
Br.
Chris
Br.
Chris
