I have three flip fluid simulations with minor tweaks that I have saved out as .sim files. Then, in the DopNetwork I read them back in using three file nodes and used a switch node to control when each one is read. Now I would like to import them into SOPS where I intend to surface them.
The problem I am experiencing is that when I use the Object Merge, Dop Import, or Dop I/O nodes to read in the switch node all I get is the collision geometry and not the flip particles. Is there a button I forgot to click?
Reading .sim files
4611 4 2- heatherken
- 3 posts
- Sadjad Rabiee
- 1391 posts
- heatherken
- 3 posts
- Sadjad Rabiee
- 1391 posts
- josyzhaocn
- 3 posts
Sadjad RabieeYou hit the nail. I met the same problem. It turns out when I use file node to import .sim file, the ".sim" suffix isn't included in the list by default. Thank you very much.
I don't understand what you mean exactly !
When you delete collision geometry ,so you have just Flip particles now !
check my project ,Is this like your purpose ?
