Hi.
I am trying to load a hip file in a python session and get an immediate segfault hou.hipFile.load().
Is this meant to work in a default python session? It works with hython.
Importing hou was also successful and hou.hipFile.save() works.
Any thoughts?
SL 6
tried on
H12.5.469
H13.0.237
hou.hipFile.load - segfault
2441 2 1- MartinAufinger
- 51 posts
- edward
- 7899 posts
I had to google what “SL 6” was.
It's supposed to work on Linux I think, see this slightly old example which needs the python version updated:
http://www.sidefx.com/docs/houdini13.0/hom/cookbook/print_hip_stats/ [sidefx.com]
My guess is to make sure you're running python 2.7 which I think is the most commonly used code path now.
I would also help to know _where_ you're crashing.
- MartinAufinger
- 51 posts
thanks edward
i believe i was running 2.6 as I thought it should be the same as the houdini python version (H12.5)
I need to double check when I have access to the system tomorrow again.
I can successfully import hou and carry on doing operations such as creating geometry or saving a file but the crash happens immediately when i try to load a hip file (hou.hipFile.load())
glad to hear it should be working though
thanks for your help
martin
martin
