Ocean Tutorial
   16217   14   3
Hi All
I was following the latest tutorial on creating and rendering ocean surfaces.
Everything's is cool and easy until I hit render.
The render looks like a flat weirdly shaded surface.
After I exit the Mplay the mantra1 node turns red.
Its complaining that it cannot load the texture map plus a lot of stuff I dont understand?
I really think I am following the tutorial to the letter so I cant figure out why its doing this.
I am using the Houdini HD apprentice v13
Here is my scene file if someone wants to take a look
Thank you All
OceanTests.hipnc (970.4 KB)
Hey Guys,
i have the same problem
mantra is unable to load the displacement map (
Why?
I7 4790K
32GTXGB RAM
780 GHz 3GB
Win 10
for apprentice version of Houdini extension should be .picnc I think
http://vimeo.com/user7871222 [vimeo.com]
Nope
already flat
Can anybody help?
Please
something is missing in the tutorial …
I7 4790K
32GTXGB RAM
780 GHz 3GB
Win 10
I don't think ROPs create subdirectories by default - does your output path exist? Is it writeable by mantra? Maybe try directing the textures to your temp directory and see if that works…
*EDIT: I was MISTAKEN - the “Create Intermediate Directories” toggle is enabled on the renderable Ocean Evaluate created by the shelf tool.
Edited by - 2014年2月12日 21:59:14
the displacement path exist and create displacement maps.
I can´t edit the ROP
I7 4790K
32GTXGB RAM
780 GHz 3GB
Win 10
Hi! I'm having the same problem with Apprentice as well. I even reinstalled just in case I missed something. Would be great if we could get some insight. Thank you.
oceans not rendering properly.jpg (662.4 KB)
Here's what might be happening, as far as I can tell.
The shelf tool defaults try to export your displacement map as a .pic file; but when actually rendering, Houdini Apprentice writes those files out as .picnc. Because the shader is looking for a displacement map that ends in a .pic, it doesn't find it. I think you'll find that if if you change the extension in the ocean_render / output file path from .pic to .picnc, the shader should be able to find the displacement map.
In my case, I had to actually write the displacement map out manually before adjusting the output file path to end in .picnc; if I tried to change it before writing, I'd get weird permissions issues. I'm not sure if this is the case for anyone else, though, because I'm doing some other python stuff in my environment.
Thanks man …
that would be very helpfull
I7 4790K
32GTXGB RAM
780 GHz 3GB
Win 10
Although it's totally understandable to want to make this cool ocean stuff, to be fair, the tutorial page does say that if you are new, start with the First Steps lesson. Once you are more familiar with Houdini you can solve this issue quite quickly i.e. in a few minutes. Consider solving it a test of your Houdini abilities
From the page:
“Are You New To Houdini?
If you are new to Houdini and would like to follow through these lessons, be sure to download the FREE Houdini Apprentice edition then go through the User Guide and First Steps Intro lessons.
http://www.sidefx.com/index.php?option=com_content&task=view&id=2659&Itemid=166 [sidefx.com]
I had the same issues, couldn't load texture maps when trying a render.
I changed output file to .picnc in both the ocean preview and the ocean render and now it works.
Next question: How would one get a boat to stick to the ocean and interact with the waves?
Been playing with the Ocean Surface in H13, when I scale my grid up
I start to see a grid pattern in the render, and not sure where it is coming from, see attached.
I've subdivided the grid and tried editing a lot of parameters but nothing
changes this, anyone any pointers?
This is often related to displacement. For your surface geo - click on the cog icon and edit parameters. Under rendering you will find the option to expose displacement bounds so you can set this value yourself to something larger.
Might not be the best way to fix way but it sounds do the trick
Will try that out, thanks
That works well, thanks revilodesigns
