Hi all,
I have a question in H13.
I try to copy an object to points of particles.
and scale this object with attribute of particles like AGE by stamping.
I attached simple test Hip file.
As you see particles have non zero value for AGE.
but stamping do not work well.
hope someone could give me some advice ?
Thanks,
takahiro )
stamp with particle attributes
7799 8 2- fujii
- 19 posts
- stevenong
- 1634 posts
Hi Takahiro,
You just found a bug. It seems the attributes created by the new POPs is causing the Copy SOP's stamp function some confusion.
If I use the old POP Network and create particles, your example works right away.
If you need this to work in the meantime, you can reference age with a point() function in the Stamp SOP.
Please submit a bug report through the Support > Submit Bugs and RFEs link above.
Cheers!
steven
Cheers!
steven
- Solitude
- 373 posts
- fujii
- 19 posts
- Sadjad Rabiee
- 1391 posts
- fujii
- 19 posts
- Sadjad Rabiee
- 1391 posts
- Ilan Gabai
- 13 posts
- fujii
- 19 posts
