Just noticed the get/set alembic cache size functions in the _alembic_hom_extensions module.
The default cache size seems to be 50 which isn't too big. Does the cache size affect all alembic functionality like the alembic primitives too or is it just for the python access to the archives?
o.
alembicGetArchiveMaxCacheSize()
3150 4 0- olliRJL
- 72 posts
- wolfwood
- 4271 posts
I believe its a cache of IArchive references, handles to the various Alembic files themselves. When you are using more than 50 alembic archives the archive reference that was used longest ago is released and a new handle created. Whenever one of our tools assembles a scene it sets the cache size to be 1024, but that's mainly cause we typically use 1000+ archives for a bigger shots.
Versions of Houdini before 12.5.487 you *had* to set your cache size to always be more than the number of alembic files you'd be using otherwise caches might ensue. This bug has since long been fixed.
- olliRJL
- 72 posts
Thanks - yeah I got that it's the number of handles to alembic archives but what does for example the GL implementation of abc primitives actually do if I have say 100 unique (static) abc archives referenced and the cache size is the default… will it start juggling the data in'n'out or is it only a concern when accessing animated archives?
…and I guess there's no way to set the cache size through the environment?
- wolfwood
- 4271 posts
olliRJL
You can set it in 456.py and be done with it. Although before jumping through hoops it might be best to profile it and see if it actually has an impact on performance.
- olliRJL
- 72 posts
Wolfwood
I did a bit a testing and didn't notice any effect in the viewport perf with static abc archives even if the cache was set to as low as 1. I guess once the data is on the GPU it doesn't need an handle to the data anymore which makes total sense.
Could maybe some SESI folk shed some light on this matter - where does this cache size practically come into play? is there any downsides to setting it too high?
