Hi XSI users! I did my second rig in Houdini, I'll try to animate it
http://www.youtube.com/watch?v=4qRagQTsE4E&feature=youtu.be [youtube.com]
RIG of Alien
10272 16 4-
- Max Evgrafov
- 13 posts
- freaq
- 300 posts
- anon_user_89151269
- 1755 posts
- Sam Howell
- 86 posts
- phrenzy84
- 249 posts
Very nice.
On the subject of your facial controls.
The problem i always have with these types of rigs is there are so many channels to keep track of.
They are super intuitive but in the end i always opt for controls Inner Brow Up/Down etc instead of curves that have separate XYZ channels. Problem is using Set Driven Key (ala Blendpose or Lookup chop isn't as intuitive as it needs to be and some scripting effort is required to make it more automated/streamlined).
Are you using any Set-Driven-Key-like setups in your rig?
- Keith Johnson
- 30 posts
Max - this is looking really nice.
I'd love to hear what you think of the rigging workflow in houdini, especially as related to bendy/squishy cartoon rigs that require layers of deformations and shapes.
Are you rigging the same way you did in xsi ?(I'm assuming that's where you're coming from). Or have you had to adapt to new methods? How is the performance of the rig?
- Max Evgrafov
- 13 posts
- Max Evgrafov
- 13 posts
- Max Evgrafov
- 13 posts
- Max Evgrafov
- 13 posts
scene with a character
https://dl.dropboxusercontent.com/u/96857127/Alien.rar [dl.dropboxusercontent.com]
- Max Evgrafov
- 13 posts
- Max Evgrafov
- 13 posts
- phrenzy84
- 249 posts
- Carioca
- 16 posts
Hi Max,
I have a question about your scene. When I grab a controller and translate it “screen up” it goes “screen up” as in Softimage (using the center of the gnomon). But when I try to do the same in a new scene, it just translates in the XZ plane (which feels really weird…)
How did you manage to have this behavior? Is is a preference? Is is an object attribute?
Thanks in advance.
Thanks in advance.
- Keith Johnson
- 30 posts
If I'm not mistaken, the behavior you are seeing has to do with whether the viewport grid is visible. If the grid is turned off, grabbing the center handle of the transform will move it in screen space. If the grid is visible, it will move in a plane parallel to the grid. Try turning the grid on and off and see if that does it.
- Carioca
- 16 posts
- edward
- 7855 posts
