Altering glue strength in sop solver
   Views 3024   Replies 3   Subscribers 2
Hi everyone,
I have a simple problem when altering the glue strength inside a sop solver with attribwrangle. In the attached file, if you switch to sop solver inside dops (switch is in sop level) glue doesn't get updated. however it updates in sop level. No big problem but i just wanna find out why.
Any ideas? and thanks.
Change_Glue_Strength.hipnc (242.3 KB)
https://sergeneren.com/ [sergeneren.com]
In the attribwrangle the attribute name should be “strength”, not “Strength”.
cwhite
opps thanks for the fast feedback. that's the downside of being a noob.
With these attribute overrides, hover over the label on the specific constraint DOP and invariably it will be the actual parameter name that you use and not it's label.
