Hi everyone
I'm new to the forum and I'd like to ask about the ram memory usage.
Two months ago I bought a computer with 64GB RAM.
When I do a geometry cache, render, etc … my RAM ranging from 8-45GB. Sometimes it is limited to 8 and do not understand how this can happen if my computer has 64BG …
I check my cache manager and it's correct.
Please can someone help me?
thank you very much
Problem with ram memory usage in Houdini
10079 15 3- robert_rapach
- 7 posts
- PradeepBarua
- 443 posts
- Jack.N
- 72 posts
- robert_rapach
- 7 posts
PradeepBarua
Houdini uses RAM how much it actually needed.
If you want to utilize full power of your hardware, use linux!
Thank you very much for the reply!
ok, I'll install linux. Which is the best operating system? Ubuntu, Debian…? When I have installed Houdini on Linux, I have to change preferences to utilize full power of the hardware?
- robert_rapach
- 7 posts
Jack.NPradeepBarua
Of course I think this is just for Win7 and before , Because I heard that RAM management on Win8 is changed and better than Win7 , something like Linux !
I've windows8 and the problem persist
- Sadjad Rabiee
- 1391 posts
- Skybar
- 166 posts
- PradeepBarua
- 443 posts
It's never answered question. It's depend on your taste. None of them is bad. It's unfair to rank them.
As beginner, you can try with Ubuntu. It have nice support. Personally I prefer Mint over Ubuntu. CentOS is now days very popular, most of the VFX companies using it (mine too). But it's hard to setup for beginners.
Linux has LiveCD, you can try before buy (I mean install because linux is free).
You need not to do anything. Linux will take care of rest.
- anon_user_37409885
- 4189 posts
- SreckoM
- 379 posts
- robert_rapach
- 7 posts
- Sadjad Rabiee
- 1391 posts
robert_rapach
You've been very helpful for me. Finally, I'll install ubuntu Thank you very much to everybody
Before do that , I suggest you to use LIVE CD mode for both Ubuntu and Mint (or even others) , So you don't need to install them on your system.Just test them and see which one is better and simpler for you (my meant is GUI) , Mint and Ubuntu has same core (actually Mint is pretty like Ubuntu in Core , But with different GUI) , Maybe Mint's GUI is better for user who was working with windows before !
- robert_rapach
- 7 posts
Joker386robert_rapach
thats a good idea. I'll keep that in mind! thank you very much
- demoan666
- 4 posts
SreckoMHi,
You just need to understand how hardware and software works. It will not change anything if you switch to Linux .
Could you please elaborate on that a little more, or perhaps point to some resources where I can read/ learn more from the POV of utilization of max resources while doing sims in Houdini (especially flips/ fem).
m.
- 8045 posts
demoan666SreckoMHi,
m.
Why do you want to use MORE resources? Generally in computer science, the aim is to strive for less.
- eikonoklastes
- 396 posts
The confusion is that the OP seems to think Houdini is under-utilising the available hardware. It didn't help that the immediate response was to switch to Linux. Objectively, yes, Houdini under Linux can potentially squeeze more out of your existing hardware, but in this specific situation, Houdini doesn't need to use all the available RAM to do its work. It is using as much as it needs, or as much as the node graph you have built can use. What @SreckoM said, switching to Linux for this particular case won't make any difference to you, in terms of Houdini using RAM.
