Hey,
just installed the H14 apprentice version on my Ubuntu machine.
My complete interface is just black also the viewport. Older Versions of Houdini are correctly displayed.
Has anybody similiar issues?
My System
- Ubuntu 14.04
- Nvidia GTX 660
- tested with latest and old Nvidia driver (304/340)
Cheers, Martin
Houdini 14 Graphic Issue
16876 22 4- louisx
- 46 posts
- malexander
- 5212 posts
- louisx
- 46 posts
- malexander
- 5212 posts
- louisx
- 46 posts
ah… yes i get some errors
ERROR: /home/martin/houdini14.0/config/Dialogs/14.0.201.13/DirectManip/cplanedialog.dialog.ui (112): Syntax error: syntax error
ERROR: /home/martin/houdini14.0/config/Dialogs/14.0.201.13/ObjectEditor/JEDI_CameraMenu.dialog.ui (12): Syntax error: syntax error
ERROR: /home/martin/houdini14.0/config/Dialogs/14.0.201.13/VIS/vis_marker.dialog.ui (15): Syntax error: syntax error
/opt/hfs14.0.201.13/houdini/soho/parameters/IFDmantra.ds Warning(897): Invalid range specification
/opt/hfs14.0.201.13/houdini/soho/parameters/IFDmantra.ds Warning(927): Invalid range specification
/opt/hfs14.0.201.13/houdini/soho/parameters/IFDmantra.ds Warning(1455): Invalid range specification
- edward
- 7899 posts
- Mykolas Sadauskas
- 5 posts
- heiligeslama
- 6 posts
- Alexey Vanzhula
- 538 posts
- Mykolas Sadauskas
- 5 posts
- edward
- 7899 posts
Which locale are you guys using and what are the exact problems? Please submit a bug report:
https://www.sidefx.com/index.php?option=com_content&task=view&id=768&Itemid=239 [sidefx.com]
- Mykolas Sadauskas
- 5 posts
edward
Bug report submitted.
- Olaf Finkbeiner
- 323 posts
- Alejandro Echeverry
- 691 posts
- NSDesign
- 16 posts
I'm also having some display issues with H14 apprentice Windows 7 nVidia Quadro 3000 laptop.
Seems to happen when drawing drop down and pop up windows. For example, when opening the geometry spreadsheet attributes drop down - a black area is drawn where the drop down should appear, then things kind of lock from there, sometimes I can get out of this by doing Crtl Alt Del and selecting Task Manager and then just returning to Houdini. It's been difficult to reproduce the issue consistently so I haven't reported it as bug.
- -Adrian
- 24 posts
- Alexey Vanzhula
- 538 posts
- merlino3d
- 65 posts
+1 for a fix!
right now I have to start H14 as sudo … isn't practical :?
the only way it works is
sudo LC_ALL=C /opt/hfs14*/bin/houdinifx
so I can't open a file double clicking on it (and yes … i'm new to linux but I've tried any other solution and doesn't works )
Linux 17.1 Rebecca
Ati 7980 (14.501.1003)
Marco
Linux 17.1 Rebecca
Marco
- edward
- 7899 posts
- merlino3d
- 65 posts
