How can I restart a pyro sim from the last .sim file?
   4855   4   4
How can I restart a pyro sim from where it was stopped? I have .sim files, and I've read it's possible, but how? I'm using a dynamics node in the out context to start the simulation. I'm reading it in using the checkbox at the top of the pyro_sim node in the object level.
If you wanna continue your simulation from last simulated frame , you can use Explicit Cache , Just Save your simulation with this option to the *.sim files , then you can continue your simulation from last simulated frame later (Just Press Play Button ! ) :wink:
Rabiee.Sadjad@Gmail.Com
Would that work if I were caching from a dynamics node in the OUT context? …using HQueue?
It will work from anywhere if have wrote down required sim data to disk.
PradeepBarua
hwy i want to continue a cloth sim ,from the last frame of my files,how do i go about doing this?
the xon can
