In asset Type Properties->Basic I can see field Maximum Outputs which is set to 1 and disabled.
Also I read somewhere in the forum that Houdini 14 has possibility to set more than one output in hda.
So, is it possible?
HDA multiple outputs
7477 4 2- Илья Фивейский
- 9 posts
- 8730 posts
- Илья Фивейский
- 9 posts
- 9krausec
- 66 posts
I've created a HDA out of a Subnetwork box in the OBJ context and I'm having issues setting it up with multiple outputs in the Operator Type Properties.
I'd like to export the position of a null within the HDA to be used for parented outside of the HDA. How would I get multiple inputs to work? (right now my Maximum Outputs is set to “1” and grey'd out in the type properties).
Thank you for any help.
- jon3de
- 22 posts
