Is there a way to activate/deactive sin wave in hscript?
   Views 6253   Replies 9   Subscribers 2
Is there a way to activate/deactive sin wave in hscript? For example, I inserted sin($F * 20) in my translate X but I don't want it to keep moving constantly…. I would like it to start the shake at frame 10 and lasts for 10 frame and easeout and stop…. Is it possible?
Just create a new spare parameter via “Edit Parameter Interface” ( let's call it “mult” ) and multiply your values with that. So your expression will look like this: sin($F * 20) * ch( “mult” ). Then you can animate the multiplier and let it fade out. While you're at it you could also substitute the “20” with a speed parameter 8)
Edited by - 2015年7月28日 08:42:25
shake_it.hip (48.7 KB)
If you're looking for a solution via expressions only,
then you can use fit() inside an if() statement:
if( $FF > ch(“start”), fit( $FF, ch(“end”), ch(“end”) + ch(“fade”), sin( $FF * 100 ), 0 ), 0 )
where “start” and “end” is your shake frame range and “fade” is the fade out length.
shake_it_expression.hip (48.5 KB)
To make things worse for the eye, here's a version with fade in and fade out
fit($FF,ch(“start”),ch(“start”)+ch(“fadeIn”),0,fit($FF,ch(“end”),ch(“end”)+ch(“fadeOut”),sin($FF*100),0))
shake_it_expression_2.hip (48.7 KB)
Hahaha, blackpixel, you cracked me up after another long and stupid day! Amazed that you can play that far with the basic sin expression, sooo cool!
I have done some search earlier but only found the camera shake tips at Setting up Cameras page if($F%2, 1, -1) * easeout()
But not sure why it only works with camera cry Anyway, I like yours better, so much more control, thanks again!
davidave
…But not sure why it only works with camera :cry: …
it works with any channel
you can as well set following for the full time segment:
sin($FF*100)*bezier()
then still adjust bezier values and handles in animation editor while the result will be multiplied by the sin()
CG Supervisor
Framestore, NY
So adding a sin() on top of keyed animation, never realized that can done!!!!
Thanks for the tip, Tomas!
davidave
while you can do that be aware that the expressions are set for channel segments, so from current to next keyframe
so if you do sin($FF*100)*bezier() and place several more keyframes and adjust the bezier, the expression on each would be unique, meaning that if you then change it to sin($FF*10)*bezier() it would change the expression only for current segment and not for others, making it slightly more tricky to mantain continuity and keep it transparent
CG Supervisor
Framestore, NY
Mind blown!
Did not know you could do that! I've always done that kind of thing by creating a spare parameter and putting my multiply curve in there and then doing:-
sin($FF*20) * ch(“parm”)
This new way I get to see a cool sin curve being multiplied down to nothing in the channel view.
Sweet!!
Just realised you also get that view when multing by a spare parameter. 8)
Still cool though.
