Why disappeared tips (help)?
   5333   12   2
For a long time I used the tips. They are comfortable and in new version of H14 they no longer exist. Why were they removed?
So, what is it? No one has a problem with that? I'm impressed 8)
I have this problem too. It worked, as you say, but seems to come and go - if you resize the window the lists appear occasionally, but tooltips are no longer visible for a while now.
Felix6699
you are a houdini master when you know all the commands on the fly:-)
i think there was a discussion about that problem. if you want you can make a bug report:
https://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=25347 [sidefx.com]
mandrake0
Felix6699
haha, I have very short memory, after a hard day's work and of good sleep, I forget to everything . Is so so, what commands need to write … Oh hell, no tips!
i too have this problem and it really sucks. It was so obviously broken I was sure it was already logged as a Bug?
edit: It was already logged as a known issue. bug #65554
Really fast reply from SESI. Amazing.
hey guys, I have the same problem.
it's very hard to compile an expression (or a path) without the assist.
Any news about the fixing?
thank yopu in advance
I downloaded the last Daily and this has not yet been fixed.
Please Guys! We are not all Houdini Gurus.
reinaldo.furegato
It's even more frustrating when you are new and learning the software by following a course that is explaining things about the quick help and you aren't able to follow :x :evil: ops:
It's been working in Houdini 15 for a while now; have you tried the latest daily build? If that's still not working, file a bug with support.
I'm o.d.d.
I wasn't sure if i should download daily builds or wait for production build. Still new in the world of Houdini. Getting the latest build. Thanks.
Oops, I meant to say production, but it's been in H15 for a while now. I can't remember which build exactly, but I'm seeing Python, vex, expression tips now.
Or are you talking about parameter tool tips? I know some times, under certain conditions (which I've never been able to reproduce), the descriptions will go away, and it'll only display the parm name.
I'm o.d.d.
I have the latest production build which is 15.0.347 and when i would type stamp( i couldn't get the tips like the tutorial i'm following. Just installed daily build 15.0.375 and now shows up
