15.5.480 -unable to compile toolkit/samples/field3d
   3398   7   1
Hi there!
On Linux, I've sourced houdini_setup and have gone into toolkit/samples/field3d.
As instructed in the README, I then run the following:
hcustom -L $HDSO -l Field3D f3dtools.C
I then get a series of compiler errors. Things like:
/toolkit/include/UT/UT_StringHolder.h:251: error: expected ‘;’ before ‘noexcept’
/toolkit/include/GA/GA_EdgeGroup.h:60: error: ‘nullptr’ was not declared in this scope
/toolkit/include/SOP/SOP_Node.h:891: error: expected ‘;’ before ‘override’
…amongst other errors. Smells like there could be a missing compiler flag.
Has anyone successfully managed to compile this?
What Linux is it? Smells like complier issue (no c++11?) What version of gcc?
(it works fine on CentOS 7.1)
Thanks for the quick reply symek. It's CentOS 6.8 and gcc 4.4.7. This version should support c++11, right?
I'm not sure if Houdini 15.5 officially requires C++11 (probably not since 4.8 is first version fully compliant with it), but gcc 4.4 doesn't support nullptr for example. If I'm not mistaken gcc 4.6 is the oldest working version out of the box (at least for 15.0 it was true). You may try to tune gcc flags (like -std=c++11), but it's pure speculation. On the other hand CentOS6.8 should work with gcc 4.7 rather painlessly [access.redhat.com].
We dropped support for gcc 4.4 because it didn't have C++11 support, and there were several bugs that made working with it rather painful. Just install a later gcc version (4.7+ works fine, not sure about 4.5-4.6) from apt.
Hi there!
Thanks very much for the replies. Although I managed to install gcc 4.8.5 just now, and it seems I'm getting the same errors…
From the same shell I'm running hcustom, if I run “gcc –version”, it tells me it's 4.8.5 so it's clearly looking at the correct version…
Also just tried the demo from here:
http://www.sidefx.com/docs/hdk15.0/_h_d_k__intro__compiling.html [sidefx.com]
for SOP_Star.C. Got a load of very similar errors.
Do you think there could be anything else missing here?
Edited by abvariant - 2016年7月22日 12:38:01
which g++
points to correct compiler too? I remember at some point newer gcc on CentOS6.x had similar problem, shell was reporting good compiler, but CMake was using old one (might confuse some details now). You could create Makefile and include $HT/makefiles/Makefile.gnu as described in docs. There are variables to overwrite CC and linker manually there.
Symek, that was exactly what the problem was. I'd never checked that the latest install of g++ was being used. As soon as I updated this, everything compiled happily!
Thanks loads!
