Marvelous Machines Entry [WIP]
   28121   61   5
redaborchardt
If by coil you mean the thread, I can do a 1 minute tutorial on that if you like.
Sure, thanks Also can I see a larger version of your first screen capture; the one containing the network ?
【T】【C】【S】
Christopher R
redaborchardt
There you go. Quick tutorial.
Good tutorial
I didn't quite understand why the following did not give the proper results but putting @ptnum in a variable worked ?
@P.z = @ptnum;
【T】【C】【S】
I think it's because ptnum is treated as an Integer, meaning whole numbers only. That would explain the jump you get instead of the smooth interpolation between whole units.
By declaring a float, I get around that issue. There might be a more elegant solution to this.
How did you do the coil from post #12 ?
【T】【C】【S】
Let me do a tutorial on that too tomorrow
Here is your tutorial. I hope you will find it useful.
Excellent, thank you
【T】【C】【S】
redaborchardt
Hi Reda, great work on the project so far! A-ok with you if we publish that tutorial in our social channels?
- Chris
Of course. That would be my pleasure.
Here are some chain links with tutorial
Since my entire model is made of SubD cages, it looks like I have reached the stage where my 6 core i7 in Mantra is outpacing my GTX 1080 in Octane. The time it takes to pre-process the scene in Octane is almost 1 minute.
I reached a real low yesterday night because I don't seem to be making the progress that I was hoping for. The mind boggling number of shading and rendering options in Mantra is making me feel really stupid.
Anyway, today I managed to get to a stage where the basic shader I built in Mantra looks somewhat acceptable.
Edited by redaborchardt - 2016年10月29日 10:35:28
Slowly getting to a stage where the shaders are starting to look probable at scale and the object seems to be made by man made tools.
Edited by redaborchardt - 2016年10月29日 11:20:21
After yesterday's low, I have now hit a high. Looking back at the progress, it does seem like the time I am spending learning Mantra is paying off.
Edited by redaborchardt - 2016年10月29日 12:03:12
Today is a good day. It feels like the victory of willpower over fear, uncertainty and doubt.
My confidence in my ability to get Mantra to do what I want is increasing. I have definitely overcome a mental block.
Mantra still boggles my mind tho!
Edited by redaborchardt - 2016年10月29日 16:13:32
Lovely chains
Edited by redaborchardt - 2016年10月29日 17:53:49
Wrapping up the day.
A new day has started
Quick test render under different conditions to check that I haven't done anything utterly stupid with the shaders.
I have stopped using the Disney shader and now using Mantra Surface nodes.
Edited by redaborchardt - 2016年10月30日 09:33:15
The irregular cog army has arrived
Edited by redaborchardt - 2016年10月30日 10:47:48
