Hi All,
Has anyone had any success with overriding Houdini's python sys.excepthook?
I'm using it for automated error reporting for our pipeline scripts.
houdini doesn't object if i pass sys.exepthook a custom function, but it never gets called.
cheers,
chrisg
overriding sys.excepthook
4117 4 2- doctorbob
- 30 posts
- Loqy0815
- 3 posts
Hi there,
having the same issue here.
We would like to use Raven/Sentry for Error-Logging (https://github.com/getsentry/raven-python) [github.com]
which is build around sys.excepthook
basically:
in any “normal” python-shell this just prints
in the houdini-python-shell I still get the usual Traceback
is this expected? Am I'm missing something here?
cheers
Loqy
basically:
def handle_exception(exc_type, exc_value, exc_traceback): print "there was a issue" sys.excepthook = handle_exception print 1 / 0
"there was a issue".
Traceback (most recent call last): File "<console>", line 1, in <module> ZeroDivisionError: integer division or modulo by zero
cheers
Loqy
Edited by Loqy0815 - 2016年11月22日 07:39:40
- doctorbob
- 30 posts
Loqy,
the last comms i had with sidefx about this was:
in summary, you can override excepthook in the python shell window, but not shelf tools.
cheers,
chrisg
I was told that Houdini's Python shell (in the GUI) uses Python's code.InteractiveInterpreter class which, for whatever reason, doesn't use sys.excepthook. The following code will change it to use sys.excepthook:
import sys
import houdiniInterpreter
def showtraceback(self):
sys.excepthook(*sys.exc_info())
houdiniInterpreter.HoudiniConsole.showtraceback = showtraceback
However, for other uncaught exceptions, like shelf tools, there's currently no way to customize the exception callback. There is an RFE submitted for this
cheers,
chrisg
- Loqy0815
- 3 posts
- shadesoforange
- 201 posts
Hey!
I know this has been many years ago, but maybe there has been an update to this, since we would also like to do automatic error reporting
Is there nowadays a way to override exception handling basically for any python code executed within Houdini. It could be within
* Shelftools
* Python nodes
* HDAmodules
* Node/Parm callbacks
Hooking intofor the Python shell worked, but no success so far for any of the other topics.
I also tried overriding the following:
Any input would be appreciated!
Cheers!
* Shelftools
* Python nodes
* HDAmodules
Hooking into
sys.excepthook houdiniInterpreter.code.sys.excepthook houdiniInterpreter.sys.excepthook
Cheers!
Edited by shadesoforange - 2023年3月31日 03:51:33
Manuel Köster - Senior Technical Artist @Remedy Entertainment
https://www.remedygames.com/ [www.remedygames.com]
http://shadesoforange.de/ [shadesoforange.de]
https://twitter.com/ShadesOfOrange_ [twitter.com]
