Hey guys,
I was wondering if it's possible to use an input meshes vertex colour for something like scattering points but then deleting the vertex colour so that the output mesh doesn't have a colour set.
Mike
Use input mesh vertex colour but don't create colour set
3414 1 0- wywait
- 25 posts
- chistof
- 52 posts
Hi Mike,
It seems like it's the vertex attribute N which is converted to color set somehow, if you add an Attribute Delete SOP and remove N from the vertex attributes then no color set should be created.
From my experience using Maya/Vray/Abc/Houdini combination, I have the feeling that it's a natural behavior with Maya to convert vertex attributes to Color Set to be able to use then in shaders like UVs for example but I might be wrong on that.
Hope that helps
Chris
Hope that helps
Chris
Edited by chistof - 2017年1月29日 08:41:16
