Houdini 16 Shader: Mantra doesn't render when PBR Reflection layer is added to dual shading model PBR Diffuse
   3259   1   2
I'm working on a leaf shader inside Houdini 16 and I came across strange problem.
I set up a dual shading model for PBR Diffue using ‘isfrontface’ condition, so for the front face I'm using Diffue and for back face Translucency and I get the result I wanted. But then when I plug in PBR Reflection after that, render gets stuck at 0.0% and nothing happens. Rendering without isfrontface condition with PBR Reflection layer works fine for both diffuse and translucency, but as soon as I add this condition Mantra is not respoding.
Any ideas why this is happening?
Attached shader network.
Thanks a lot,
Wojciech
https://www.artstation.com/wojciechpiwowarczyk [www.artstation.com]
I used the condition to mix between two BSDFs rather than two Diffuse Models and that seems to work fine!
