python Multi-line String
   7678   3   1
In “Edit parameter interface” We can create “Multi-line String”, but I can not find how I can achieve it in python??
I read the api, find this attribute,but I don't know how to set it.
http://www.sidefx.com/docs/houdini13.0/hom/hou/StringParmTemplate [sidefx.com]
itemGeneratorScript(self) → str
Return the script used to generate menu items, or an empty string if there is no such script.
This script is used when this parm template uses a menu.
Note that if the item generator script language is hou.scriptLanguage.Python, this script may be either a single-line Python expression or a multi-line body of a Python function.
thanks
Embed “\n” newlines into the script?
For everyone who find this old topic (like me), to create a multiline string parameter. You have to modify the key “editor” value to 1.
import hou
node = hou.node('/obj').createNode('geo')
group = node.parmTemplateGroup()
folder = hou.FolderParmTemplate('folder', 'My Parms')
template = hou.StringParmTemplate('myparm', 'My Parm',1)
template.setTags({"editor": "1"}) #it's "0" by default
folder.addParmTemplate(template)
group.append(folder)
node.setParmTemplateGroup(group)
Edited by nilth - 2017年5月5日 13:37:54
Thank you for this. It pointed me in the right direction.
If you want a multiline string param to use Python:
...setTags({"editor": "1", "editorlang": "python"})
If you want to inspect a node the asCode function is really nice.
To write it to a file we can execute snippet below in the python shell
with open('/path/to/somewhere/as_code.py', 'w') as f:
    f.write(hou.node('obj/geo1/your_node').asCode())
