I made this asset in houdini, following a tutorial of Entagma.
I have tried to export it as fbx, alembic and obj but I can export it successfully.
Alembic: Export the groups but not geometry
FBX: Export full geometry but not groups
OBJ: Export only 2 booleans, the third one is missing.
I attach the scene, maybe some one could try to export it? I am very new with the software, and I don't find anything about it. I hope someone can give me a hand.
Thanks for your time
Impossible to export it right
2787 4 1- JavierVerdugo
- 10 posts
- adk
- 6 posts
I just quickly tested this with an OBJ and all the booleans / groups do come across.
Different apps will pick these up differently obviously, in LW the groups come in as parts (GIF).
I'd test other apps but my main machine is out of action.
Also, I simplified your test setup, just a lot less polys and scattered points, as it's pretty heavy to play with on my old laptop here.
- 7990 posts
- JavierVerdugo
- 10 posts
- adk
- 6 posts
JavierVerdugo
Hello guys, thanks for the responses.
ADK you told me you simplified my asset but you didn't attached it!
All I did Javier was decrease the poly count on the internal boolean (the one that produces all the irregular noise/cuts along the y axis) as well decrease the internal sphere count (scatter SOP) and their poly count. Not sure if I saved it but happy to reproduce it if you need. It took too long to cook otherwise.
