Python promote parameter
   2468   2   1
I am trying to mimic the Hda's ‘Promote Parameter’ behavior, using python.
I've been able to add hda's parameters, with default values, using:
oParmTemplate = hou.StringParmTemplate(…
oParmTemplate = hou.ButtonParmTemplate(…
oHdaDefefinition.setParmTemplateGroup(oParmTemplateGroup)
But I can't find how to add a ‘Linked channels’, in the channels section (Edit Operator Type Properties –> Parameter).
Is it possible to do so using python?
Thanks,
Jonathan
I know this is an old post, but I had to do something similar and took the approach below:
Suppose we want to promote the parameters tx,ty and tz from a node right inside the hda
# node: a node right inside the hda
hdaDef = node.parent().type().definition() # get HDADefinition
parmTemplateGroup = hdaDef.parmTemplateGroup()
targetParmTuple = node.parmTuple("t") # get parmTuple for t (which holds tx,ty,tz)
targetParmTemplate = targetParmTuple.parmTemplate()
parmTemplateGroup.append(targetParmTemplate)
hdaDef.setParmTemplateGroup(parmTemplateGroup, rename_conflicting_parms=True) # update HDA
for parm in targetParmTuple: # link node parameters to HDA parameters
    parm.setExpression(f'ch("../{parm.name()}")')
# XXX: Might need some more tweaking on the targetParmTemplate in some cases
# XXX: the HDA needs to be saved manually after the script
Houdini Version: 19.0.383 (Python 3, which is now the default )
thanks for sharing!
I always struggle when I need to work with parmtemplates
