H16 Hardsurface modelling exploration
5722 10 2-
- MagnusL3D
- 1110 posts
Inspired by HardOps / Fusion 360 / Modo / Modo - Polystein etc. I made myself some HDA (tools) in Houdini to help myself model more efficiently in Houdini. This is the results so far, I've used a base shape I saw in some HardOps post since I thought it was a good test case for the different HDA's (tools).
The HDA's (tools) so far I've named: ‘edge sweep’, ‘edge clone’, ‘edge warp’, ‘mesh_split’, ‘hex_screw’. They all revolve a lot around beeing able to create interesting mesh to use with Boolean rather quickly. And the ‘mesh_split’ I have done to facilitate myself a new workflow where I work from a base shape and split of pieces with the ‘mesh split’ to further refine that inside a ‘subnet’ which helps my node graph in Houdini to not explode into 1 million nodes.
You can view things in better quality over at Artstation here:
https://www.artstation.com/artwork/8nmmm [www.artstation.com]
- Konstantin Magnus
- 690 posts
Looks great! Would be nice to see the tools in action (maybe on Vimeo).
- _Christopher_
- 767 posts
- MagnusL3D
- 1110 posts
Konstantin MagnusYeah. well see about that, there are some more HDA's I want to do and mature the existing ones. But one day…perhaps
![](/static/djangobb_forum/img/smilies/big_smile.png)
Christopher_RGeneral shape is inspired by a post I saw several months ago from the HardOps guys, the detailign is just random stuff out of my head.
What mechanical machine is this from ?
- _Christopher_
- 767 posts
- Cyzor
- 181 posts
- MagnusL3D
- 1110 posts
Christopher_RWho knows what the future holds
@MagnusL3D I wouldn't mind a tutorial how you began to create the shape ?
CyzorSuch nice words for my doodle
Entrancing intricacy to the orderly industrial cuts along with the smooth, flowing curves. Conveys a sense of no-nonsense, hardened equipment developed with technology just a bit ahead of contemporary capabilities.
- anon_user_89151269
- 1755 posts
Looks good!
I'm curious, how did you deal, if at all, with the shading artifacts caused by so many n-gons? Did you control the normals for each continuous surface part or you didn't have to deal with shading artifacts at all? One solution to get rid of those shading artifacts is to go Sub-D, but that's obviously off the table with the topology you have there.
- MagnusL3D
- 1110 posts
McNistor
Looks good!
Thanks! The way I deal with shading this thing is just using the Normal SOP with the “Weighting Method” set to “by Surface Area”.
- 1755 posts
- aoakenfoArchiact
- 65 posts
