Fractal SOP bug
   2119   0   1
Found a bug (I assume) in the Fractal SOP, H.8.0.383, Linux.
1) Throw down a Grid SOP, Mesh or Nurbs, size 10x10.
2) Append a Point SOP, add color, set to your fav color, for kicks add alpha and set to some value between 0-1.
3) Append a Fractal SOP and open the spreadsheet to examine the Cd values.
Most of the Cd values get multiplied. Change the divisions on the Fractal SOP and the Cd values change and the fix boundry switch affects the Cd values too.
–Mark
Edit: Still the same with 8.0.410, will try 8.0.544 later tonight
You are no age between space
