Saving Redshift Materials
   Views 11169   Replies 3   Subscribers 1
I recently moved from C4D to Houdini and I was wondering what the process is for creating a Redshift material and saving it to the material gallery? I created a RS Material Builder node and went about creating a basic material but I can't find a way to save it to it's own gallery. Also when I update the shader ball icon it just goes to white. I noticed in the material palette gallery you can filter by renderer but Mantra is the only option and there doesn't seem to be a way to add gallery folders to the palette. As a noob I'm sure I'm missing something so any help would be appreciated.
Bump.
Have you tried asking in the Redshift forums? I'm curious about the answer as well.
>>Kays
You should be able to Right-Click on the RS Material Builder node > Save > To Gallery. Then specify the gallery file in the Gallery File parameter.
Not sure if you are still looking but this is very helpful - https://www.youtube.com/watch?v=6NDWZILuwps&ab_channel=olegzv [www.youtube.com]
