Just build a new machine, installed new Ubuntu and Houdini.
But Im getting some issues with display and in general. When I run help window Im getting weird display failures. Like GPU is failing or completely freeze the whole system.
Houdini on Ubuntu
7636 14 3- JozefPlata
- 14 posts
- uuLLFA
- 90 posts
JJ FX
Which version of Ubuntu are you using? The recommended one from SideFX is LTS 14. I find that Mint 18 had great support for Houdini
- Wren
- 532 posts
- JozefPlata
- 14 posts
- goldleaf
- 4200 posts
- JozefPlata
- 14 posts
goldleafYeah did that too. And now I cannot even start Houdini. It completely freeze after splashscreen when the main window loads up.
The Proprietary Nvidia drivers, if you haven't already
Gonna try other distribution, as this might be an actual GPU failure. This is a brand new GPU card, so rather unlikely, but….
- SreckoM
- 379 posts
- JJ_FX
- 30 posts
SreckoM
I am using it on 18.04 with Nvidia without problems. I am almost 100% sure you did not install these drivers correctly. What does it says in About section?
Actually I reinstalled new system as I might have done few things not the way I should. Because last time I upg the nvidia drivers in terminal. This time I did that in settings manually. And I managed to run Houdini.
However still sometimes I get some viewport glitches, and aftet that I get a crash. But this time at least there was a backup file created.
Right now I have just:
1) Installed Ubuntu
2) Did updates manually
3) Updated NVIDIA drivers manually. However still in About section the system shows me gpu type NV60 (or sth like that, im at work now) but I have GTX1060.
And thats it for now. Ive read that you need gcc too for houdini. Not sure what that is actually, but know how to install it from terminal.
Im rather new to Linux, always worked on Win.
- SreckoM
- 379 posts
No need to complicate so much.
First turn off Secure boot in BIOS. Did you do that?
When you say manually and terminal, what exactly does that mean? I install Ubuntu drivers by going Software updater and Additional drivers and check Nvidia proprietary.
No need for installing gcc, you have all that.
important thing is to turn off Secure boot.
- malexander
- 5216 posts
- Enivob
- 2633 posts
I just installed Houdini 16.5.496 on Ubuntu 18.04 and I get a crash on launch.
I can still launch and use H16.5.378 just fine.
Any tips on how to get past a “HOM_OperationFailed” error?
Edited by Enivob - 2018年6月12日 12:27:57
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- JJ_FX
- 30 posts
- Enivob
- 2633 posts
My issue was a 3rd party render system, Redshift was not compatible with the .496 release. Once I upgraded my Redshift to the latest version, which is matched to the H16.5.496 API, and altered my houdini.env to point to the new plug-in Houdini launched just fine.
This API mis-match could be an issue for Arnold users as well.
- JozefPlata
- 14 posts
Ok so I checked today. And I have to say it finally recognize my GPU (GTX 1060). I might not have restarted the system after installing the drivers.
And the drivers Im using are proprietary Nvidia drivers. Exactly says:
Using NVIDIA driver metapackage from nvidia-driver-390(poprietary, tested)
Ive read about this Secure Boot and Im not so sure if I want to disable it now. Lets wait a day or two and see if I keep getting crashes and issues with viewport.
- SreckoM
- 379 posts
