HDA multiple outputs
   7653   4   2
In asset Type Properties->Basic I can see field Maximum Outputs which is set to 1 and disabled.
Also I read somewhere in the forum that Houdini 14 has possibility to set more than one output in hda.
So, is it possible?
yes, it is possible for SOPs created from subnet (subnet itself has already 4 outputs)
then use Output SOP to redirect your data to specific output
So it is possible only for SOPs? (In my case I need it for COP.)
I've created a HDA out of a Subnetwork box in the OBJ context and I'm having issues setting it up with multiple outputs in the Operator Type Properties.
I'd like to export the position of a null within the HDA to be used for parented outside of the HDA. How would I get multiple inputs to work? (right now my Maximum Outputs is set to “1” and grey'd out in the type properties).
Thank you for any help.
9krausec
+1
https://vimeo.com/jon3de [vimeo.com]
