Fluid Source SOP gone?
   24815   7   1
I've encountered this problem a few times after following along with various fluid simulation tutorials online, but I can't seem to find any information online re: whether the Fluid Source SOP has been replaced in Houdini 17. What is the new node/method to create a fluid source? The FLIP Source node's parameters are totally different from the Fluid Source's. Sorry if this is a noob question, I've just started learning Houdini. Thanks!
I can't see the fluid source
Hey guys,
Are you looking for the “Volume Source” node in DOPS? It should have a particles tab along with your surface volume.
Shortcuts are supposed to be hard, if they were easy then they would just be “The Way”.
I think it is the sop level one, the operator was hidden because there is a new workflow in 17.
Open a hscript textport and execute then you will have it in the tab menu:
opunhide Sop fluidsource
buki
Shh, we don't speak of such things.
I am having the same problem. Trying to follow Andreas Glad tutorials & have come unstuck due to the updated nodes.
Very new to Houdini & no tutorials for the updated system.
Try this in the Texport:
opunhide Dop sourcevolume
Then in the Dynamics context, you should be able to get an old-style sourcevolume node
Hi guys
I'm trying to use the fluidsource node to transfer some vel into a DOP Network. However, the velocity doesn't seem to affect the simulation, it appears as vel.x, vel.y and vel.z.
Can I ask for some advice?
Thanks, using Houdini 19.0.498
