Turn Edges into Curve
   89870   34   7
Oh my god, how dare SideFX?
So the Game-Dev team just went and built that tool? And in one of the videos Luiz even says, that he might change the tool defaults from “uv” to blank because “it might be useful for other places”..
Another option is to put desired eges in a gorup > polypath > blast (pick group and check “Delete Non Selected”). For some reason the Gamedev edge group to curve node crashed on me.
I wrote a sop tool that works like this.
Check this out: https://youtu.be/_0_ZnD-iusE [youtu.be]
Tinkering with the dissolve tool there are a couple things to watch out for. It only works on boundary edges therefore you may need to delete the polygons beside the edge you want to extract - that is if you are trying to get edges or loops “inside” a topology. The second step would then be to select the boundry edges you want(either by hand or with a group) and then press delete (which creates a dissolve sop). On the Dissolve SOP, set Operation to Delete Non-Selected and then set Remove Inline points to OFF - this is especially important if you selected a loop because then ALL the points are inline points and you will see nothing. If you do these steps you should be OK:
extract_curves_dissolve.hip (98.5 KB)
robsdesign
Not sure if this helps but I've found some of the tools useful…
https://www.sidefx.com/forum/topic/56685/ [www.sidefx.com]
The “GameDev Edge Group to Curve” sop might be useful for this…
I had also struggled with extracting an edge loop from a model and this worked perfectly. Thanks! It's now called “Labs Edge Group to Curve” since the “Game Dev” naming was dropped in H 18. The node's ability to “enable thickness” made me smile since it saved me having to set up a sweep.
With game dev/labs nodes, I usually close my eyes and hold my breath before seeing if I've crashed my project Most of the time, they work fine.
99% of the time Polycut works fine to extract edges.
Just invert the group selection (!group).
Edited by PaQ WaK - 2020年1月5日 12:40:20
Gameloft
rlvelocity
Luiz Kruel
Senior Technical Artist
Dissolve SOP works like a charm. Use the polypath after, then a polywire, and you have nice tubes that follow underlying geo. Some transform, then _OUT that into a light geo node and you have neon lights that follows your mesh. Neat.
Konstantin Magnus
Nathan Apffel
Its hard to believe that these are the best solutions in Houdini for extracting a curve from an edge.
Houdini is a toolbox, not a toy.
This is why the Houdini artists lack of creativity.
Paulo Cunha2
Konstantin Magnus
Nathan Apffel
as the old saying goes:
give artist a Curve From Edges SOP and he will be able to create curve from edges
teach artist how to make Curve From Edges SOP and he will be able to solve all sorts of problems without having to complain about missing tools
I personally think the second requires much more creativity, but regardless there is now a Curve From Edges SOP in Houdini (technically an alias to updated Convert Line SOP)
Paulo Cunha2
Konstantin Magnus
Nathan Apffel
Wow. Brilliant insight.
L
this all is a joke just make a curve from the edges sop and stop with all the unnecessary steps.
Houdini is falling short when it comes to simple tasks that when multiplied are costing people hours of unnecessary wasted time.
Labs edge to curve is okay but sometimes buggy.
dreamblk
what made you revive this thread?
the Curve from Edges SOP has been there for some time so no extra steps are necessary since then, however if you are running into some issues you may want to clarify more
Konstantin Magnus
Nathan Apffel
That's why I like the pluralize function.
Jobless
