Dear Forumers,
I am struggling to get a .3dm file into Houdini. I have downloaded a Rhino demo and have tried to export as a .fbx
Damned Rhino won't make the .fbx for some reason.
Hope this question shouldn't be in a Rhino forum, so does anyone have any knowledge or ideas about what to do?
Thanks,
Nick.
From Rhino to Houdini
15057 13 3- 5DN
- 152 posts
- SreckoM
- 379 posts
- 5DN
- 152 posts
- SreckoM
- 379 posts
- 5DN
- 152 posts
- goldfarb
- 3462 posts
- 5DN
- 152 posts
- sl0throp
- 258 posts
With Rhino, I have had varied success with .obj and often I get exports out of Rhino using the .iges format, this will give you the curves and reconstruct the nurbs meshes in Houdini, this can then be converted to Polys, with some control. I find that it works really well, but you can end up with some dense meshes.
- 5DN
- 152 posts
sl0throp
which .iges type is the best?
- nicholas_yue
- 301 posts
- neil_math_comp
- 1743 posts
nicholas_yueI don't think anyone's worked on it, (though I could be wrong), but if you'd like it, feel free to RFE it, via Support > Report a Bug/RFE. The submission form is still under construction for the new website, but the old form should still work and is here [archive.sidefx.com].
Is this still a problem i.e. importing Rhino's *.3dm file directly/natively into Houdini ?
- colors
- 3 posts
- NasAlkhaldi
Houdini modeling is a pain in the A**, ive spent the hole day trying out different things but non worked. and the ones that worked didnt give me the result i needed but i found the best way is to export as dxf from rhino to 3dmax and import it to houdini via sidekick FML!!! there is a utube tutorial about sidekick just type in nyx sidekick.. Houdini fix this please!!!!!
- ashcic
- 17 posts
I've had similar issues, but in the end, I found the following method worked for me:
1. Explode the object
2. Shrink Trimmed Surfaces
3. Change Degree - change to 3
4. Join
5. Export as IGES 3DS Max 5.0
I don't know if it will work for everyone, but hopefully it might be useful.
@NasAlkhaldi: Absolutely, if SideFX could improve the import options, it would enable so many more people to include Houdini in their workflow!
4. Join
