I am getting this error every time I try to access the Houdini help after that if I move the mouse anywhere inside houdini I got locked up by this message.
Anyone else by any chance is also having the same issue?
Error in mouse event handling in centos 7.6
7210 7 2- mzigaib
- 979 posts
- mzigaib
- 979 posts
More details, that is what the console prints back:
Exception in thread Thread-2:
File “/opt/hfs17.0/python/lib/python2.7/threading.py”, line 808, in __bootstrap_inner
self.run()
File “/opt/hfs17.0/houdini/python2.7libs/hou.py”, line 68171, in __threadRun
self.__run()
File “/opt/hfs17.0/python/lib/python2.7/threading.py”, line 761, in run
self.__target(*self.__args, **self.__kwargs)
File “/opt/hfs17.0/houdini/python2.7libs/hdefereval.py”, line 142, in <lambda>
thread = threading.Thread(target=lambda: function(*args, **kwargs))
File “/opt/hfs17.0/houdini/python2.7libs/hdefereval.py”, line 162, in thread_code
it.next()
File “/opt/hfs17.0/houdini/python2.7libs/sas/localassets.py”, line 371, in check_for_shelf_tool_assets
shelf_tool_assets = StoreAPI(session_data).get_shelf_tool_assets()
File “/opt/hfs17.0/houdini/python2.7libs/hutil/api.py”, line 144, in __call__
**self.kwargs_for_read_url(*args, **kwargs))
File “/opt/hfs17.0/houdini/python2.7libs/hutil/web.py”, line 31, in read_url
disable_proxy=disable_proxy)
File “/opt/hfs17.0/houdini/python2.7libs/hutil/web.py”, line 143, in _create_url_connection
url_request, post_data, *extra_urlopen_args)
File “/opt/hfs17.0/python/lib/python2.7/urllib2.py”, line 127, in urlopen
return _opener.open(url, data, timeout)
File “/opt/hfs17.0/python/lib/python2.7/urllib2.py”, line 404, in open
response = self._open(req, data)
File “/opt/hfs17.0/python/lib/python2.7/urllib2.py”, line 422, in _open
‘_open’, req)
File “/opt/hfs17.0/python/lib/python2.7/urllib2.py”, line 382, in _call_chain
result = func(*args)
File “/opt/hfs17.0/python/lib/python2.7/urllib2.py”, line 1214, in http_open
return self.do_open(httplib.HTTPConnection, req)
File “/opt/hfs17.0/python/lib/python2.7/urllib2.py”, line 1187, in do_open
r = h.getresponse(buffering=True)
File “/opt/hfs17.0/python/lib/python2.7/httplib.py”, line 1045, in getresponse
response.begin()
File “/opt/hfs17.0/python/lib/python2.7/httplib.py”, line 409, in begin
version, status, reason = self._read_status()
File “/opt/hfs17.0/python/lib/python2.7/httplib.py”, line 365, in _read_status
line = self.fp.readline(_MAXLINE + 1)
File “/opt/hfs17.0/python/lib/python2.7/socket.py”, line 476, in readline
data = self._sock.recv(self._rbufsize)
error: Connection reset by peer
And a screenshot of the error.
Any tips of may be causing it?
self.run()
self.__run()
it.next()
‘_open’, req)
response.begin()
Edited by mzigaib - 2018年12月15日 12:13:35
- 7on7on
- 22 posts
Same probleme here
Production Build 17.0.416
Debian 9.6
self.run()
self.__run()
it.next()
‘_open’, req)
response.begin()
Same probleme here
Debian 9.6
self.run()
self.__run()
it.next()
‘_open’, req)
response.begin()
Edited by 7on7on - 2018年12月15日 18:23:02
- mzigaib
- 979 posts
- MACHIN3
- mzigaib
- 979 posts
In case anyone else have this problem, this is what Sidefx told me to do and it helped:
Please try setting the environment variable:
LC_ALL=en_US.UTF-8
In your $HOME/houdini.env file.
If that does not work, please try setting the following ones as well:
LC_MEASUREMENT=en_US.UTF-8
LC_NUMERIC=en_US.UTF-8
I hope it helps someone.
LC_ALL=en_US.UTF-8
Edited by mzigaib - 2019年5月15日 15:10:39
- polvy
- 8 posts
- Punkt
- 10 posts
