How could I split a geo using polysplit..?
2679
6
2
- Masoud
- 414 posts
Hi;
I tried to to split a geometry using a curve, but it's not working…
Here I attached my scene.
Thanks for helping.
Polysplit.hip (68.0 KB)
Masoud Saadatmand (MSDVFX)
- Andr
- 899 posts
I guess u might want to use a boolean to do that?
check this example and see if it helps,
cheers
splitGeo_from_curve.hiplc (143.8 KB)
- Masoud
- 414 posts
Andr
cheers
Hi Andr;
I want to cut the geometry using a curve, not a surface (So I don't want to extrude the curve).
Thanks.
- lapacho
- 3 posts
You don't need a PolyCut SOP. Split the vertices in splitPathGroup before using ExplodedView SOP.
Edited by lapacho - 2019年1月30日 09:32:14
- Masoud
- 414 posts
lapacho
Hi lapacho;
You mean “Vertex Split SOP”? if yes, how?
- lapacho
- 3 posts
Hi Masoud,see attached.
Best!
Edited by lapacho - 2019年1月31日 09:59:36
Polysplit.hip (83.8 KB)
- Masoud
- 414 posts
Thank you lapacho.
