PolyExtrude in VEX
   6636   10   2
I've been wondering if anyone tried to recreate the polyextrude sop in vex? I'm particularly interested in the inset function of the sop, and how one would go about recreating this in vex.
Any ideas?
Thanks in advance.
you just need to add points in the direction of a surface's normal, connect the dots and make a surface out of it
following this thread.
I always wanted to try to build one in vex because the original one can't be compiled.
Andr
That's exactly why I'm asking hehe.
ouroboros1221
Thanks for your answer.I guess I'm looking for a bit more specific information on how to do that. Sorry my question wasn't clear enough.
Here I made a simple example, it's up to you to figure out how to procedurally organize the points so you don't have to type them in.
vex_extrude_v01.hipnc (81.9 KB)
Simple VEX inset. Run over prims.
vector centerPoint = v@P ;
int pts[] = primpoints(0,@elemnum);
int newPTS[] = {};
//generate inset points
foreach( int pt ; pts )
    vector pos = point(0,'P',pt);
    vector insetPos = lerp(pos,centerPoint,ch('inset'));
    int newPt = addpoint(0,insetPos);
    append(newPTS,newPt);
//inset prim
int prCenter = addprim(0,'poly',newPTS);
//contour prims
for(int i=0; i<len(pts); i++)
    int pr = addprim(0,'poly');
    addvertex(0,pr,pts[i-1]);
    addvertex(0,pr,pts[i]);
    addvertex(0,pr,newPTS[i]);
    addvertex(0,pr,newPTS[i-1]);
//remove original prim
removeprim(0,@elemnum,0);
Ideally you also interpolate point and vertex attributes on the inset points.
ouroboros1221
Thank you. Unfortunately, your file doesn't work properly, geometry is all messed up with open prims flying everywhere. But it's a starting point.
Nicolas Longchamps
int newPTS[] = {};
//inset prim
//contour prims
Thank you for your example. Simple indeed but very interesting.
Here I got it fixed. If anyone figured out how to procedurally connect those points, please let me know.
vex_extrude_v02.hipnc (91.0 KB)
v@extrude_distance = @N * chf("distance");
int @pts[];
int @ptsOnPrim[];
    @ptsOnPrim = primpoints(0,chi("selection"));
    foreach(int pt; @ptsOnPrim)
            vector pos = point(0,"P",pt);
            i@point = addpoint(0, pos + v@extrude_distance);
            append(@pts,@point);
       //setpointattrib(0,"pts",@primnum,@pts,"set");
int i = 0; int j =0;
addprim(0,"poly",@pts[i+2],@pts[i+1],@pts[i],@pts[i+3]);
addprim(0,"poly",@ptsOnPrim[j+1],@ptsOnPrim[j],@pts[i],@pts[i+1]);
addprim(0,"poly",@ptsOnPrim[j],@pts[i],@pts[i+3],@ptsOnPrim[j+3]);
addprim(0,"poly",@ptsOnPrim[j+1],@pts[i+1],@pts[i+2],@ptsOnPrim[j+2]);
addprim(0,"poly",@ptsOnPrim[j+2],@pts[i+2],@pts[i+3],@ptsOnPrim[j+3]);
if(@primnum==chi("selection"))
    removeprim(0,@primnum,1);
only works with a grid and it has duplicated primitives, waiting for some more advanced user to improve the code
Here is my solution, works well, but only with quads, connect a grid into the 0 input of a primitive wrangle:
//Vex 'extrude' function...Only works with 4 sided faces!!!
//pick a polygon face/primitive
int index = chi("Primitive_Index");
//this array will hold newly created points
i[]@newpt_list;
//let's extrude the selected primitive (using Primitive
//Index we created above)
if(@primnum == index){
    //set selected prim color to white - just a visual aid
    @Cd = {1,1,1};
    //primpoints function gives us all the connected
    //points, as index values
    i[]@conn_pts = primpoints(0,@primnum);
    //let's run through this points list, and then
    //create a new point above them
    foreach (int pt;@conn_pts) {
        //get the connected points position vector
        vector curr_pos = point(0,"P",pt);
        //create an offset vector, this will be our extrude amount
        vector offset = set(0,chf("offset"),0);
        //calculate the new position, adding old pos with offset
        vector new_pos = curr_pos + offset;
        //create a new point at this new position vector
        int newpt = addpoint(geoself(),new_pos);
        //add the new point index to an array, will need these indexes
        //to create the top and side faces
        append(@newpt_list,newpt);
    //create the 'side' poly faces - this bit needs more 'elegance'
    addprim(0,"poly",@conn_pts[3],@newpt_list[3],@newpt_list[2],@conn_pts[2]);
    addprim(0,"poly",@conn_pts[2],@newpt_list[2],@newpt_list[1],@conn_pts[1]);
    addprim(0,"poly",@conn_pts[1],@newpt_list[1],@newpt_list[0],@conn_pts[0]);
    addprim(0,"poly",@newpt_list[0],@newpt_list[3],@conn_pts[3],@conn_pts[0]);
    //remove the original prim face
    removeprim(geoself(),@primnum,0);
    //create the new 'top' poly face
    addprim(0,"poly",@newpt_list);
//color non-selected prims blue, visual aid
else{
    @Cd = {0,0.5,1};
...well, it works...the tricky bit is creating the 'side' faces...if you know the extruded poly is a quad, you can 'cheat' by creating the faces in a predefined order:
However, the code will break if the extruded face has more or less than 4 points...
The code that works for any n-gon will be something like:
1)calculate how many new points were created, say 'total points'
2)for i in the range of newly created points:
3)create a polygon(@conn_pts,@newpt_list,@newpt_list,@conn_pts....
4)and then the 'exception': create a polygon(@newpt_list,@newpt_list,@conn_list,@conn_pts
I have since improved my result to include polygons with any number of connected points, i.e. 3 or 5:
i[]@newpt_list;
    @Cd = {1,1,1};
        //vector offset = set(0,chf("offset"),0);
        vector offset = @N;
    int len_conn = len(@conn_pts);
    int len_newpt = len(@newpt_list);
    for (int i=0;i<len_newpt;i++)
        addprim(0,"poly",@conn_pts[len_newpt-(i+1)],@newpt_list[len_newpt-(i+1)],@newpt_list[len_newpt-(i+2)],@conn_pts[len_newpt-(i+2)]);
    //addprim(0,"poly",@conn_pts[3],@newpt_list[3],@newpt_list[2],@conn_pts[2]);
    //addprim(0,"poly",@conn_pts[2],@newpt_list[2],@newpt_list[1],@conn_pts[1]);
    //addprim(0,"poly",@conn_pts[1],@newpt_list[1],@newpt_list[0],@conn_pts[0]);
    //addprim(0,"poly",@newpt_list[0],@newpt_list[3],@conn_pts[3],@conn_pts[0]);
else{
    @Cd = {0,0.5,1};
