Qt5, Qt Warn
   Views 8966   Replies 13   Subscribers 3
hello
In houdini 16,Qt5, whenever I try to open the python panel, It shows this kind of error and a white panel that says page not found ( for Quick Start: calendar Example) :
Qt Warn: /deep/ combinator is deprecated. See
https://www.chromestatus.com/features/6750456638341120 [chromestatus.com] for more details.
is something wrong with my installation?
thank you
I haven't seen this warning before but it sounds like Qt's WebEngine (for web rendering) is failing for whatever reason.
Are there any other messages outputted to the terminal? Or just the Qt warning?
Also, out of curiosity, are you able to open the Quick Start example using the Qt4 Houdini build?
Rob
rvinluan
yes … just the warning line mentioned.
rvinluan
no problem with houdini 15.5 (Qt4) .
but in houdini 16 Qt5 .. It says web page not found!
haven't tried houdini 16 Qt4 yet!.
thankx
Can confirm, happens whenever I open Python Panel. Houdini Apprentice 16.0.504.20
Not sure how to use the Panel yet though, complete new user here.
Dig some googling and it sounds like the ‘deep’ warning can occur if Qt's WebEngine is failing to load a web page. So it alerts that there is an error but doesn't indicate what that error is.
Anyway, can you try putting this Python code in a shelf tool and click on the shelf tool to see if it produces a more detailed error message?
from PySide2 import QtWebEngineWidgets
web_view = QtWebEngineWidgets.QWebEngineView()
# Temporarily store web view in hou.session so Python
# does not auto-destroy the browser when the script finishes execution.
hou.session.webview = web_view
web_view.setUrl("http://www.google.com")
web_view.show()
I'm curious to see if Qt WebEngine is foo-barred in general or just the quick start example in Python Panels.
If the above script runs successfully, then try replacing
with
file://<HFS>/houdini/python_panels/quickstart.html
where <HFS> is the path to your Houdini installation:
- <HFS> => C:/Program Files/Side Effects Software/Houdini 16.0.ZZZ on Windows
- <HFS> => /Applications/Houdini/Houdini16.0.ZZZ/Frameworks/Houdini.framework/Versions/Current/Resources on MacOS
- <HFS> => /opt/hfs16.0.ZZZ on Linux
Also, what operating system are you using?
Rob
thank you
As soon as I get the latest version I'll try this.
rvinluan
I'm on Window 10 64bit.
Using this code as suggested with my install path I set this to a tool on the shelf. When executed it produced the white error window described above
web_view.setUrl("file://C:/Program Files/Side Effects Software/Houdini 16.0.0.504.20/houdini/python_panels/quickstart.html")
web_view.show()
Which produced the same errors as above with the same Houdini Console Error of
See https://www.chromestatus.com/features/6750456638341120 [chromestatus.com] for more details.
I want to edit to say that I did correct the double zeros in the install path…silly me
Edited by doodle - 2017年3月13日 15:47:38
doodle
web_view.show()
Thanks for testing.
After further investigation it appears to be a Windows-only bug with opening web content from local files.
Still investigating…
Rob
hello
trying to do it again with the latest version of Houdini but still get the same error.
ps: do I need to report a bug on this one? because It is very annoying!
Edited by MirHadi - 2017年3月31日 08:23:55
hadi jam
hello
This bug should be fixed in tomorrow's 16.0.565 build. Please give it a try.
And yes, for future reference, please submit a report when you encounter a bug.
Thank you
I got 16.0.565, and unfortunately seems like the problem persists.
I hope It is not only me getting this kind of problem.
Weird. I tried 16.0.565 again on a Windows machine just to double-check and opening a Python Panel works for me. Previously on that machine with an older build the Python Panel opened blank followed by the /deep/ combinator is deprecated warning.
I wonder if there is a system setting that is additionally preventing the Python Panel's quick start example to load.
Perhaps try blowing away the QtWebEngine subdirectory (if it exists) from your Houdini user preferences directory? (i.e. %HOME%/houdini16.0/QtWebEngine).
And if that doesn't work, can you try installing the attached default.pypanel file into %HOME%/houdini16.0/python_panels/default.pypanel. You may have to create the python_panels directory if it does not already exist.
I'm curious to see if that will get the Python Panel working for you though you may run into unloaded images in the quick start example.
Rob
yes, I deleted the QtWebEngine folder.
created the python_panel before and I have something there .. like vexeditor.papanel and It works just fine.
but the problem with that issue still persists!!
same error.
I'm getting this in 17.5 as well.
