Single + Multi node inputs...
   4751   7   1
Can we create a digital asset that uses a single input 0 and multiple inputs after?
I've seen this for some nodes inside Houdini although I can’t find them right now. But I made a Photoshop montage of what I would like to do. The first input on the left is the mandatory one and all others are using a bar like the right part of the input.
Possible to do currently?
Thx!
Christian
Edited by cs_pix - 2019年5月6日 14:37:46
this isn't currently possible for user defined nodes.
Training Lead
www.sidefx.com
Any plan to change this maybe ?
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
goldfarb
Can I achieve it with HDK?
I couldn't find the HDK code to achieve it
forever_kk
goldfarb
The only thing you can do is set the input amount to a value, as in the figure below, to 28+ (depends on the gui scale?), to merge the inputs into a single one - but this does not behave exactly like the input in the merge op.
Edited by viklc - 2023年8月1日 11:19:28
vik_lc
forever_kk
goldfarb
The only thing you can do is set the input amount to a value, as in the figure below, to 28, to merge the inputs into a single one - but this does not behave exactly like the input in the merge op.
Thank you for response.
But I need single + multi.
Because I need to type different things, I need to make a distinction.
Would certainly be a good addition to the HDA definition.
Resurrecting this thread to add my voice to this. It would indeed be great to have in a lot of situations.
