I have been working on a character rig that requires the character to hold a weapon in either hand. We are able to get the Weapon attachment points on either hand. Now, I am setting up a constraint that allows the characters left or right hand to be constrained to the hand guard/barrel of the weapon. It works on one side of the character and not the other.
My process to lock the right hand to the hand guard/barrel of the weapon is: Select the R_hand_bone_auto null, select Blend, Simple, RX RY RZ, select Target Object which is a Null (L_Weapon_Attach) placed at the point of contact, Select Enter. I also do this for the R_arm_bone_goal_auto, instead I use the TX TY TZ values. Then I setup an additional IK Space Switch for the L_Weapon_Attach.
This works perfectly, and now I try the same process just reversed with the Left side. This time I get a CHOP error that I just can't figure out. I have tried starting with the Left side instead of the Right and still the same error.
I did try building the Constraint network manually and still the same errors. I have also tried to recreate the three nulls for the L_hand, and no errors have appeared. When I try to constrain the L_hand_bone to the L_hand_bone_ctrl the hand loses all function. Does anyone have an idea of what this error could mean? Thanks!
Rigging CHOP Error - Blend
1978 5 2- GlenD
- 118 posts
- goldfarb
- 3459 posts
- GlenD
- 118 posts
- Guillaume
- 478 posts
I got the scene from Michael and had a quick look. There is an evaluation cycle when you add the second constraint. I think it comes from the constraint installed on L_arm_bone_2 which pulls from L_hand_bone_ctrl. The solution might be to add new OBJ nodes to prevent the cycle or to use a Fetch CHOP node instead of using a CHOP_Object node.
- GlenD
- 118 posts
GuillaumeThanks, I'll give it a try!
- GlenD
- 118 posts
@Guillaume The Fetch Chop worked well in the L_arm_bone_goal_auto and L_hand_bone_auto. I had to use a Transform VOP to reverse the translations that I needed.
In the end I actually went a different direction. I added another Object Offset to the Parent Blend lock the L_arm_bone_goal_auto to the R_Weapon_Attach null that is located where the hand holds the barrel of the weapon.
I used a Look At Constraint for the L_hand_bone_auto to Look At the R_Weapon_Attach. This gave us the rotations needed to keep the hand on the barrel. Then we just have to fine tune the hand animation instead of creating a brand new animation for the entire L Arm and Hand.
Thanks for the help!
