Mantra stopped working after installing Redshift.
Does anyone has any solution for it. I have setup env file as mentioned in Redshift installation guides.
HOUDINI_DSO_ERROR = 2
PATH = “CProgramData/Redshift/bin;$PATH”
HOUDINI_PATH = “CProgramData/Redshift/Plugins/Houdini/17.5.229;&”
I am using Houdini 17.5.229, Redshift 2.6.41, Windows 10 and GTX 1070 Ti
Mantra not working after installing Redshift
6423 9 2- Kanitk86
- 4 posts
- TwinSnakes007
- 648 posts
- omerkucuk
- 4 posts
I have the same issue. I am not getting an error message. It says just “generating scene…” on the render view tab. or if I try to open the render panel with a mantra node than there is a nothing. Render screen is not opening. If I delete the redsift code in the env file than everting is ok. Mantra is working.
Edited by omerkucuk - 2019年8月22日 18:48:09
- Kanitk86
- 4 posts
- zetavfx
- LuFu83
- 5 posts
- zheng_shu
- Pixelised
- 35 posts
I was just running through a tutorial from Etnagma and also got issues with using Mantra, it can't seem to find a license even though I'm running the Indie version. Has Solaris broken Mantra rendering, or installing my Octane Studio license broken it?
I really want to finish the final steps of the tutorial and want to stick with Mantra for the time being.
- rustytoe
- paloskin
I fixed issue by enabling RedShift via json package.
In my case the problem was on a macbook m1.
I tried to configure RedShift via
After a little digging I noticed that removing
Anyway, I created
Make sure you set the
I hope this helps someone.
houdini.envbut mantra stopped working.
PATHsection from
houdini.envhelps. I haven't tested this well enough so this solution may cause problems
Anyway, I created
/Users/YOUR_USERNAME_HERE/Library/Preferences/houdini/HOUDINI_VERSION/packages/redshift.jsonfile and put the next content to it:
"env": [
{ "RS_PLUGIN_VERSION": "20.5.370_arm64" },
{ "REDSHIFT_COREDATAPATH": "/Applications/redshift" },
"HOUDINI_PATH": "${REDSHIFT_COREDATAPATH}/redshift4houdini/${RS_PLUGIN_VERSION}"
{ "PATH": "${REDSHIFT_COREDATAPATH}/bin" },
"PXR_PLUGINPATH_NAME": "${REDSHIFT_COREDATAPATH}/redshift4solaris/${RS_PLUGIN_VERSION}"
RS_PLUGIN_VERSIONto correct one.
