Hou.putenv Error
   3215   2   1
I need to set some environment variables, attached to a scene.
Ex: hou.putEnv('RENDER', ‘/path/to/my/projectA/projectARenderFolder’)
I could have to update that variable several times within a houdini session:
IE:
Open scene B
hou.putEnv('RENDER', ‘/path/to/my/projectB/projectBRenderFolder’)
Open Scene C
hou.putEnv('RENDER', ‘/path/to/my/projectC/projectCRenderFolder’)
Having an outputPath (mantra), using environment variable works well within houdini session…
$RENDER/$OS/$F.exr …
However, when I save scene, reopen, or send it to farm, $RENDER is not defined anymore.
Is it possible to declare a variable, and making it ‘saved’ in current scene?
hou.putenv('RENDER', ‘/x/x/’)
thanks,
Jonathan
If the question is still on, here's the answer:
You should use this:
hou.hscript('set -g ' + 'RENDER' + ' = ' + '/path/to/my/projectC/projectCRenderFolder')
I am using hou.putenv and it doesnt get saved with the scene. I can confirm the hscript method works. thanks.
https://www.youtube.com/channel/UC4NQi8wpYUbR9wLolfHrZVA [www.youtube.com]
