controlling voxel size in vdb from polygon
   3579   5   0
Hello guys,
Is there a way to control the voxel size of VDB from polygon, say using a map or a noise. What I want to do is blur details on a geo I am working on while keeping details in some areas.
Thanks in advance
You can have multiple VDBs with different resolutions but voxel size is constant in a single VDB. What you might be looking for is a VDB mask to localize the blurring.
Would controlling density per voxel help accomplish your goal?
You could do something like that with a volume wrangle:
https://www.sidefx.com/docs/houdini/nodes/sop/volumewrangle.html [www.sidefx.com]
at the bottom of the list under volume are some functions to aid in that process:
http://www.sidefx.com/docs/houdini/vex/functions/index.html [www.sidefx.com]
Thank you Nicolas,
Now that I know voxel size is constant, I'll try and find a way to combine them. I couldn't find a VDB mask, only the VDB occlusion mask.
Thank you babaJ, I will check this out. I am not sure if volume is what I am looking for in this paBticular case.
Edited by Ray56 - 2019年11月19日 11:11:30
I think you may be misunderstanding me. Using a volume wrangle does not mean volumes exclusively. It's working on the voxels - So you could work on the voxels with say, the volume wrangle after a VDB from polygons(set to DistanceVDB - surface).
Of course I don't know ultimately what your after…but here's an example how you might do some work with the voxels.
VDB voxel wrangling.hiplc (78.6 KB)
