Bad parent found. (parent is not a network)
   2440   2   0
So unclear whether this is a Houdini specific error or there is possibly something wrong with my Redshift materials.
But when I simply try and cook a ROP Geometry Output node in TOPs I get lots of the following errors
Similar to this error but I am not using HQUEUE or submitting to a farm
https://www.sidefx.com/forum/topic/69162/ [www.sidefx.com]
Edited by art3mis - 2019年11月19日 13:59:20
Bad parent found.png (246.6 KB)
Looks like the environment in which hython is running is not configured correctly, as the errors are due to the missing redshift plugin.
hi!
have you ever solved this issue? could you get it to ignore those errors and start your rop geometry output node task?
