[solved] how to evaluate string attribute in delete node
   Views 4217   Replies 3   Subscribers 0
The geometry has an attribute “id” which contains string values for each polygon.
How shall I refer to it in the “filter by expression” option in the delete node?
I tried the following, and they didn't seem to work:
@id = "Building A"
`@id` = "Building A"
@id == "Building A"
`@id` == "Building A"
Edited by oat - 2019年12月13日 00:50:06
Hey Oat,
one way is using a partition node and convert your id string to groups by typing id into the rule field. After that you can delete by group in the delete node.
But I guess there are other ways.
CYTE
in Delete SOP expression you may need to use this
strcmp(@id,"Building A")==0
however you can use Blast SOP instead and in Group parameter type:
@id="Building A"
CG Supervisor
Framestore, NY
Thank you, tamte. Both of your suggestions work like charms.
I'm glad that I learned a new trick from you.
