Color visualisation disappears
   2378   2   1
Hi, I'm learning how to use Houdini and following some tutorials from Applied Houdini, speaking of following the tutorial, I'm fine and learning a lot. Still, I come across a small issue and can't find the solution. I'm using Houdini 17.5, I'm applying the Voronoi and visualising the different pieces, but after packing the geo with the Assemble node, I can't see those visualisations, I thought was something correlated with the Cd attribute but I can't get it back, I followed that video so many times. I'm doing it the same, although he uses v16. Any workaround?
Kind regards,
Giovanni.
2020-02-16 03 27 47.png (314.2 KB)
2020-02-16 03 27 18.png (289.8 KB)
I don't think the gpu can see the attributes inside packed geometry.
jsmack
Thanks.
Interesting, but in the tutorial, he definitely does visualise the colours inside the packed geometry, maybe a bug?
