render all takes?
   Views 14736   Replies 14   Subscribers 2
Hi guys, is there a way to render all takes one after another?
I have several takes and only one mantra render node and there's an option to render with current take or choose any but I can't find a way to make it render all takes.
Thanks,
Adrian
One option would be to create as many mantra nodes as you have takes, set each one node for each take, link the nodes together (if they all render the same frame range than it's easier), select the parent node and hit render.
The nodes should render one after the other. Although I did have issues with it in the past (which could pretty much be a mistake of mine), that's how it should work.
Toronto - ON
Thanks Rafaels. I'll make a render output for every take but it's going to be harder to manage, plus some have different frame ranges so that makes the workflow even more complicated.
I'm wondering how they do it in big productions
You could write a python script that updates settings and renders using one mantra node.
Drive, monkey, drive!
Well not me I couldn't
adrianlazar
Yeah, me neither, not yet!
Anyway, here's what I would do, if you want to check it out…
render_setup.hipnc (190.2 KB)
Toronto - ON
i think one mantra node per take is better and clearer to manage on a renderfarm
Martin
Thanks Rafaels, I'll take a look at that scene.
sanostol, why?
one mantra node for all takes means that You have to override all rendersettings in the take, including pathes and so on, and I just think it is easier to have a node for every take. it more visual.
and in the renderview You can select which pass to render by selecting the node without switching to that take.
takes can be confusing, and for me that works best.
when I want to render all passes I just use a merge on all rops and it's fine
Martin
Thanks for the explanations.
How is the merge node handling different render ranges? If I daisy chain together rops with different render ranges than all of them will use the range of the last one.
adrianlazar
Not necessarily, you just have to put “Render Frame Range Only (strict)” in the Valid Frame Range option. It seems to work better if the last node in the chain is the one with the largest frame range.
I also just checked Sanostol's tip and there is indeed a merge node in the render context. I never used it since I didn't even know of it's existence before…
Toronto - ON
I nest takes into a parent take, and then use a Wedge ROP on the parent take, which renders the children.
faulknermano
Could you please explain how to setup wedge, because for me it does not work. It renders only one take which is selected in “wedges number” even in “all wedges” rendering mode.
Here's a script to render all takes. I put it on my ropnet node. Select the ropnet node, click the gear icon -> Edit parameter interface. Then create a button. Put this in the callback script:
for take in hou.takes.takes(): hou.takes.setCurrentTake(take); hou.parm('execute').pressButton()
Make sure the language is set to python for the callback script
mfiorilli
Just wanted to say thank you for this little tip! Saved me a whole lot of trouble.
