Hey guys just wondering if there is a workflow for using Redshift with crowds in Houdini. I tried style sheets but it doesn't seem to be compatible. I saw online about a shader switch method but not sure how that would work with Houdini agents. Any ideas?
**UPDATE**
So Saul Espinosa helped me on the redshift facebook group, he said “To support the materials override in the agents from the “agentshapename” attribute, the plugin promote this attribute as “name” to all the final primitives once the agent is expanded at the extraction time, so in your case you only need to set as “Primitive name or path Attribute” condition the agent shape name.”
So basically just need to have target primitive, and change the condition to primitive name or path attribute since that's how redshift looks for the agents at render time.
Redshift Crowd Workflow
5543 5 0- mannyw
- 31 posts
- polvy
- 8 posts
mwillustrationsSaved my life, thanks.
**UPDATE**
- brokenkeyframe
- 56 posts
- Sebastien Levieux
- 63 posts
- Toketronic
- 40 posts
- Toketronic
- 40 posts
