GameDev Tools Custom Installation Shelf
   5505   7   2
Hi, since installation from shelf overwrites my .env file it breaks my plugins like redshift, arnold etc. so only way to install GameDev Tools is manually for me ( i guess ). I have three questions;
1- I couldnt find a way to update empty GameDev shelf with manual installation. There is no way for that?
2- It does shows my version as “unknown” when i click on update button in GameDev shelf. Fix?
3- Actually, there is a way to install it from shelf-auto mode but not break my custom .env file or renderer installations? Because it's completely overwrites the .env file..
Hey there.
After version 1.13 it shouldn't break your plugins. We submitted a fix for hopefully smarter patching of the file.
If your file does break you can manually fix the houdini.env file by ensuring the first HOUDINI_PATH entry ends with & and subsequent ones end with $HOUDINI_PATH
Hope this helps
Luiz
Luiz Kruel
Senior Technical Artist
Still the same problem for me, even worse now on 17.5 with GameDev 1.131 - I can't get it to work again. Unless I disable GameDev entries, Arnold won't work.
Does anyone have a working .env for hou 17.5 with arnold & GDT installed?
Thanks,
jasper
planetx
Thanks,
jasper
As far as I know you need to FIRST load Arnold, and then everything else. So if that's not yet the case, try doing that. (I'm not quite sure why, but that fixed it for other users in the past)
Paul
Paul Ambrosiussen
Technical Artist, Freelance
twitter.com/ambrosiussen_p
Ambrosiussen
planetx
Thanks,
jasper
Paul
In this way, I can start the Houdini, Arnold, and gamedevtool correctly.
But when I open an existing hip file directly, all of the shop Arnold nodes are lost.Creating from there is no problem.Only disabling gamedevtool in env can solve this problem.
And some Settings are generated in the console in addition to the normal reports
like this:
HTOA environment variable already set to CUsers/16104/htoa/htoa-4.0.2_r236e192_houdini-17.5.229/htoa-4.0.2_r236e192_houdini-17.5.229
The new revision.
It's not just gamedevtool.
In houdini17.5, htoa4.0 was loaded with any plugins to cause this problem.Setting it up correctly only helps me use the tools properly.But double-clicking on the hip file will still lose the Arnold material.
Edited by particleflow - 2019年5月9日 05:51:04
Hey, best to send this to support@sidefx.com
This seems more like a Houdini problem than a GameDevToolset problem
They will be better suited to look at your issue I think
Paul Ambrosiussen
I am running into this problem as well. I have Arnold, and when I installed GameDev tools all my shaders went away. It happens with new scenes as well as existing scenes. I checked my $PATH and $HOUDINI_PATH vars and they seem to be loading all the proper stuff from a glance.
Edited by Tyler Britton2 - 2019年9月12日 16:28:43
Tyler Britton2
#PATH = “$PATH;C:/Users/User/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348/scripts/bin”
#HOUDINI_PATH = “C:/Users/User/htoa/htoa-5.1.0_r9289183_houdini-18.0.348/htoa-5.1.0_r9289183_houdini-18.0.348;&”
