Paste Relative References hotkey
   6548   5   2
Hello everyone, I'm trying the new version, and first thing I've noticed - old hotkeys are broken again.
In 16.0 it was impossible to bind Ctrl-Enter, Ctrl-Alt-Enter to a Flipbook,
in 16.5 it's impossible to bind Ctrl-Shift-V to Paste Relative References.
Actually I wasn't able to make paste rel refs working at all - with any combination of keys.
Is it just me having these weird problems, or everyone?
Besides that, it's impossible to see the “path” of hotkey user is mapping key to - they're all are just outside of hotkey manager window(middle section). It may look like something insignificant, but taking into account I'm copy/pasting refs ~100 times a day, that's a major issue(at least for me).
PS: Any chance we could get the old hotkey manager from v15/15.5? It was nice, simple and clean. Maybe as an option?
I can't help you with the hotkey matter, but have you tried to change the size of your global UI size in the General user interface to the smallest settings? It might allow you to see the path?
A.
Edited by Adriano - 2018年3月4日 23:26:31
Kthulhu Fhtagn
linked Ctrl+Shift+V to Paste Copied Relative References in 16.5.356 and it works as expected
EDIT: and for simplicity Ctrl+Shift+C to Copy Parameter as they work in tandem
Edited by tamte - 2018年3月5日 14:35:18
Ye[, it's strange. On one machine I wasn't able to do that, while on another one it's just picked up the 16.0 configuration without any problems. The point is that I copied these houdini16.0 prefs from the same source for both machines.
So I guess it works for now, but the problem with “hotkey path” is still here: it's impossible to see what you're assigning even if you will stretch hotkeys window onto 2 monitors.
Just use CTRL + V on the Hotkey. That will work.
For anyone who's figuring out where it is. Edit -> Hotkeys:
add hotkey to copy and paste parameter.png (740.1 KB)
Generalist. Transforming still images to 3D animation 🔮
Socials: https://linktr.ee/AnimGraphLab [linktr.ee]
