Textport \ Expression Field, result of the same expression
   2329   0   0
Hi there,
I've got the following problem - the same expression, entered in textport and in an expression field returns different result, here's the sample code, illustrating the issue:
dopobjectlist(“/obj/dopnet1”, dopoptions(“/obj/dopnet1”, “Obj8”,“Position”,“glueobject”), 0)
(it is supposed to return the ID of an object that is located in /obj/dopnet1/Obj8/Position/glueobject - ball1 in this case, (id) 38 )
Entered in the textport, analogous
echo `dopobjectlist(“/obj/dopnet1”, dopoptions(“/obj/dopnet1”, “Obj8”,“Position”,“glueobject”), 0)` returns 38, as expected- while the Expression field always returns 0. What is the reason of that?
Thanks.
P.S. I am trying to input this in Modify Data DOP node, float field.
I liked the Mustang
