Hello! The latest version of the Skinning converter (the one with the skinningconverter_utility) can't be exported as a skinned mesh with Fbx Rop. And in Unity, it opens like a mesh renderer.
It works when you take bonecapture, solidembed and bonecapturebiharmonic out of the skinningconverter_utility. Take a look at the screenshot attached. The left one is working, right one isn't.
I believe it has something to do with how Fbx rop is detecting the skinning.
Skinning converter in 18.0 doesn't allow to export fbx
7519 13 3-
- stassius
- 5 posts
- stassius
- 5 posts
- Ambrosiussen
- 197 posts
I must have missed the post, hence the lack of replies from my end.. Sorry about that.
Bug reports should be submitted to support@sidefx.com to get assigned to a developer for it to get fixed. Please do not rely on the forum for this, since there is no guarantee it will get picked up.. Since that's what the support channels are for
Please send a ticket to the email provided above with a file to test with, and an explanation like you already provided in your post!
Thanks,
Paul
Thanks,
Paul
- hurma
- Ambrosiussen
- 197 posts
- hurma
Hello again, thank you for your quick response. I bought a licence finally. Houdini Indie.
I installed the sideFX Labs (the latest version)
I want to export a cloth simulation into SparkAR. I created the simulation in Maya and exported the alembic file to Houdini where I used the skinning converter tool, which looks like it is working great in Houdini. Then I export the file as FBX. (then I imported the FBX file to Maya just to check if its working) But when I open it again in Maya the mesh is separated from the bones. Bones are animated but the skin is not bonded. Please help!
Edited by hurma - 2020年7月18日 05:10:06
- Nathan Srigley
- omega.ult
- Ambrosiussen
- 197 posts
- DiegoM
- 4 posts
Hello!
I see that the latest version of SideFXLabs updated the skinning converter node, where the interface has changed and there are now three separate outputs instead of one.
But is it just me or it's missing the convert button? I can't seem to find it and I feel like I am going crazy. Or is the node supposed to work completely different now? Can the documentation be updated to explain the new intended workflow?
Thank you!
Thank you!
- DiegoM
- 4 posts
Aaaand found it just a bit after posting, in the release notes for SideFXLabs. The node is now supposed to be used within the new KineFX workflow for rigging and character animation. Because I was still working in 18.0, I had managed to miss its existence entirely, so the change was really disconcerting.
So, if somebody has a similar problem, the answer is connecting the three outputs of the skinning converter node to the three inputs of the bone deform node, and also to the three inputs of the FBX character output ROP, which you can then use to export the FBX. (If I am making some mistake here please correct me, I literally just learnt of the existence of KineFX and am still trying to wrap my head around it).
Now my problem is that upon importing in blender, I get a bunch of animated empties and no armature, and the mesh is not skinned. I have no idea if that is the intended behaviour or a problem with blender's FBX importer as it's well known to be quite flaky. But I can work around that for now with the empties to bones addon and rebinding the mesh. Hopefuly this can get irnoned out somehow?
- Ambrosiussen
- 197 posts
- JudeMarv
- 4 posts
- Sirvoxelot
- 75 posts
